Recreating a patch
as requested on support…
how can i make this jpeg fit on the carbide creat v7
First, import it into Carbide Create as a background/pixel image:
then, re-draw it…
Start by re-setting the text:
Then draw in the outline:
Then go into Node Edit mode:
and turn off Snap to Grid, and edit:
Inset the geometry:
re-draw everything else:
Thanks Will! I’ve just started working on a similar project recently and was trying to figure out how to do it. This is really helpful.
How do you set the “FOREST SERVICE” text to follow a curve, yet remain vertical? or, does that fall under re-draw everything else:?
That text had to be re-drawn.
Or, it could have been re-set using a drawing program which has the option of not rotating text on a curve.
