Good point about reducing tool travel one way to make your machining process more efficient in VCarve is to machine the holes first and then set your roughing toolpaths to start closer to those areas, minimizing unnecessary movement. Grouping your operations or adjusting toolpath order can really help, and setting custom start points often makes a noticeable difference too. Have you tried separating the hole drilling and roughing passes onto different layers to see if it improves the toolpath flow?
Did you mean to post this in a different thread?
yes basically i have mistakenly this post in this thread i change the thread soon
If you’ll let us know which thread you meant this for we can move it.
A post was merged into an existing topic: Help: How Do I Reduce Tool Travel by Machining Holes Before Roughing in VCarve?
#done.
Please let me know if this works as expected or no.
yes expected i try to fix it later
