Regularizing geometry to achieve symmetry
Given a design:
one would want to set things up so as to ensure things are symmetrical.
Start by measuring things:
then changing Job Setup:
and verify Grid spacing will ensure the center is at a Grid intersection.
Select and copy everything:
Then delete everything but the circles in one copy:
Select the Circles:
Align Vectors:
and align them to the center of the Stock:
Delete all but one of the circles in the spare, and remove all but one set of the rotate geometry:
Drag into alignment with the original:
delete the duplicate circle:
Make sure the rectangle and small circle in it are centered:
Align Vectors:
Draw a circle which is larger than all the geometry:
(and centered on the Stock)
Select and duplicate in place by copy-pasting when the cursor is not in the drawing area the small circle and rectangle:
Select the larger circle:
rotate 120 degrees:
Done
Repeat:
Adjust Stock size as necessary:
For the toolpaths, one deletes now redundant toolpaths to see:
which previews as:
It is a bit confusing since there are tabs, but the part isn’t cut all the way through β€” assuming the depth of the Contour is correct:
we change this in Job Setup:
to see:
A further concern is that the No Offset Contour is reducing the size of the circle all the way around by the radius of the endmill β€” we will assume that is an error and that the geometry is the correct size.
As one can see, there is some overcutting, and a further consideration is that a tool with an 0.5" length of cutting flute is being used to cut to a depth greater than the diameter of the tool β€” to address that, create a circle which is greater in radius by the tool diameter plus 10%:
Then duplicate the original circle:
and select the duplicate and the rectangles:
and use the Trim Vectors tool to remove geometry which does not describe the central region which is being kept:
OK
OK
Use Join Vectors:
Modify the toolpath to cut this geometry and the outer circle:
Then modify the geometry for the smaller circle holes to be below this toolpath and to start their cut at the bottom:
and create a pocket toolpath which uses the two outer circles and starts at the bottom of the previous pocket and cuts down to tab height:
Then move the Outer Contour toolpath to after that pocket and have it cut the rest of the way:
