Rendering with cuts at stock depth
Hey Rob…before you go stable with this release, is there any possibility that you might resolve the issue relating to the saving default name of GCode files? Current version maintains not only the last gcode directory, but the name of the .nc file. If you’re working on a new design, that old file could get overwritten if you’re not careful because it’s full path is defaulted into the name.
We had discussed this back in April (this request), which admittedly is the Cadillac of solutions and maybe overkill…but at least change the code so that it does not persist the file name beyond the current session.
In other words, within a CC session, the name is retained, however, if I close and reopen CC, it forgets the file name of the last .nc file…It would still remember the directory, but the file name would be blank.
That must be a very simple change…would you consider it?
  • Gary
