Repetability and aligment with Nomad 3
Hi all,
I’m trying to set up a system where I can swap multiple jigs (and wasteboards) in and out of my Nomad and always keep everything in alignment. Curious whether others have solved this and how it’s held up.
In the past, I have press-fitted registration pins in an MDF wasteboard held down with double-sided tape. It worked well, even for flipping stock to machine both sides. But over time the pin holes wore loose, and the tape would shift or let go (one wasteboard came off entirely one time). It also wasn’t viable for harder materials like aluminum.
I recently tried the Carbide threaded table. But I found a few issues. It has a bit of a play before you screw it down, so it has to stay permanently mounted to keep coordinates consistent, and it’s 0.5" tall, so I would lose that machinable height. Then I would have to bore the pinholes directly into the threaded table, which is quite intrusive. Alternatively, I considered mounting an L-bracket onto the table to butt the jigs and waste boards against, but I don’t think it’ll stay precise - debris and slightly inconsistent seating would creep in over time. Also, the L-bracket I made had a bit of play as well, so the moment I would remove it and put it back on, everything would be off the next time.
Where I’ve landed is replacing the built-in bed with an aluminum replacement bed, then bore two press-fit registration pins directly into it after it’s mounted. Every waste board and jig gets two matching holes, so I can swap freely and stay aligned, and I do not lose a 0.5" height of work area. The measurements are in this thread, and High Tech Systems makes a drop-in replacement bed:
For simplicity, I could buy the bed from HTS and just bore two registration pins after mounting it.
My main question for anyone who’s done something similar: would this hold up over time? Would these pins give me mechanical alignment between jigs no matter what I swap? Or I would eventually have to replace the bed because things would get out of alignment?
There is also another concern. I still need reliable, repeatable coordinates. My plan is to probe the new mounted bed with my BitZero V2 to set X/Y, so that if I ever lose my offsets, I can recover the same zero. How consistent is re-probing the same spot in practice with the BitZero? Are people getting reliably back to the same point, or is it always a touch off? I have had some weird inconsistencies with the bit Zero in the past.
For context on the zero worry, I once hit RESET ALL OFFSETS by accident and lost all my coordinates. I’d like to hear how others guard against losing their zero and how they recover it.
Two suggestions for the Carbide team while I’m here:
  1. A confirmation prompt on “Reset All Offsets” (“Are you sure you want to reset all offsets?”).
  2. A way to save and recall work coordinates, so an accidental overwrite is recoverable.
Thanks!
Two suggestions:
  1. If the registration hole is wearing out in MDF, try pressing a bushing or other wear-resistant insert into the MDF. That will save on the wear and tear. You might also want to use a material that’s less moisture-sensitive, like a plastic or something.
  2. Have you tried Carbide Motion’s Quick Actions feature? See: https://www.youtube.com/watch?v=QI-TZltM2HY&t=525s
Thank you, Winston! I saw the quick action feature added on the latest iteration of the software, but I wasn’t sure what it was for. This is great!
I have tried Delrin with better results for inserting the registration pins, but eventually they wore off as well. A wear-resistant insert for the registration pins on an MDF or Delrin board would actually be a great solution as well. Although it doesn’t solve the height limitation.
I just found this other thread:
This solution, buying the new threaded bed from HTS where you can attach threaded dowel pins combined with the Quick Actions feature to store Zero points, solves all my issues, and I do not have to drill any new holes.
Thank you so much!
