Replacement power supply specs
I shut down and stored my SO3 for the past month during some garage remodeling. I set it all up again today and my power supply is not working. No LED on the box and no power to the board.
Is there an off-the-shelf replacement available? I have a Fry’s electronics nearby and I was hoping to use the machine all day tomorrow.
Thanks.
After doing some searching on-line, it looks like an LCD monitor supply might work. Anyone know if the pin wiring is standard? I found this one that looks like it will work. http://www.amazon.com/TAIFU-WELLTRONICS-WTS-2405W-WTS-2405s-070-7528-7874/dp/B01DPACKTK/ref=sr_1_4?ie=UTF8&qid=1461544312&sr=8-4&keywords=power+supply+24v+5A+4+pin
http://www.shapeoko.com/wiki/index.php/Power_Supply#Voltage_and_Wattage_Guidelines
This wiki page doesn’t seem to work anymore is there an updated reference link?
We now have them in our shop:
Thanks, but in my case mine was potentially dead on arrival and I’m trying to see if I can source a temporary suitable replacement from either my own parts bin or a local supplier while I wait for a response from support.
I just got a Shapeoko Pro on Friday, started assembly late Saturday and was hoping to wrap it all up and fire it up today, but I’ve hit a wall with no power and as you can imagine I’m eager to get started.
