Request To Put A Pause After Bit Setter
Have a 5 Pro with a VFD, Bit Setter and a Sweepy Pro. The Sweepy and the Bit Setter don’t always play nice together. What would be nice to be able to do is once a bit is loaded and set, have the option to go to the material being cut to set the Sweepy to the correct depth before the VFD spins up and cutting begins.
Agreed. And sometimes the Sweepy Pro will slip a bit and drop around the BitSetter when I’m not looking. Then I have to re-zero again.
