Hello everybody. I hope somebody can help me with this.
I have been trying without success to resize a Vector without the “scale factor” option.
Is it possible?
The original vector size is 132.6 mm x 40 mm when I did it in Inkscape.
Once I try to import into CC the size changes to around 10000 by 6000 mm.
Then I resize it to 132.6 mm but it automatically scale it to 42 mm(the original was 40mm, I mean 132.6 by 42mm)
Please help!
Best regards, Oscar
- Draw a rectangle of a known dimension around everything in Inkscape
- Save as an SVG
- import into Carbide Create
- select everything
- set the size to match that of the original outer rectangle
