Hello all. Getting my nomad setup and want to see if I can do this on it https://www.thingiverse.com/thing:612630
I noticed that it’s a bit larger then usable area on the nomad. How do I resize this in meshcam? Or should I do it in carbide create? Sorry for newbie questions.
I’m assuming you don’t want to scale it down, and by that I mean just make it for example 80% of full scale? Because if you are your hole sizes will shrink proportionally as well and the bits might not fit any more. I don’t do too much in meshcam but you could import into Fusion360 and cut down the sides as needed or manipulate it how ever needed without changing the hole sizes.
