Resource Question; Does Carbide Share XXL Waste Board Dim/Drawing?
Hello all,
I need to make my own waste board with holes for alignment / some sort of clamping system for when I start cutting plywood.
  1. I was wondering if anyone knew if Carbide shares drawings of the XXL wasteboard?
Making a new waste board I need to know if there is a chance in getting marks / by wrong runs making marks in the waste board. I´m thinking of making a split waste board.
First layer with 3/4 MDF
Second layer with 3or6mm MDF
Each hole in the lower waste board will have threaded interests of some sort.
I guess this is an extremely elementary question by me; that never has runned a CNC machine:
Is it a necessity to install threaded inserts in my waste board?
Using dowels ( for example 9mm in diameter ) a good alternative for alignment / holding the workpiece in place?
PS: I will then not have any for for hold down equipment ; but is this neseccary when the most sturdy material I will work with is Oak / but mostly work with plywood with 3/4 thickness.
AFAICT no public drawings for the XL or XXL wasteboard designs. Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable
Either I was mistaken, or the drawings were since published. See: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable.
Couple of different ideas at
I’m planning on PVC interspersed w/ T-track: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable
I haven’t seen one posted yet, but they have happily posted some of the others (Nomad, for example)
I’d ask for the drawing and see what they say.
Thanks!
Considering T-tracks too , now, after reading your post; WillAdams.
  • Will also make contact with Carbide via mail to ask about drawings for the washboard for the XXL.
Thanks!
My first post was a bit messy , I guess… I wrote too many questions, but I was wondering if anyone had any thoughts about ;
Clamps ( what I would call hold down equipment )
VS.
Dowels ( placed in holes in the waste board ) for just holding the workpiece in place.
  • how much force is on the machine and what equipment is necessary for fasting the workpiece?
PS: It would be great if a tap hole ( system / grid ) + dowels would do a good enough job… !
G-Wizard will calculate cutting forces I believe.
Dowels work well for locating (frequently used for that in flip jigs), and one can use them along two edges of a piece, but they have to have something such as a cam clamp, or a sliding set of wedges to actually hold things in place.
Threaded holes in an aluminum table are one option offered by Carbide3D: https://shop.carbide3d.com/collections/tools/products/shapeoko-threaded-table — I did a grid of T-nuts in an HDPE cutting board which worked well.
I found these clamps ( see attached photo ) - they look like they would do the job with t-tracks.
The clamps are listed in the resource site you added in this thread.
Trying to figure out what a flip jig is - tried to google it, with no result. What kind of jig is it?
A lot of new glossary / terms to understand here…
Thanks for the replay, again :slight_smile:
A flip jig (actually a fixture) is one which can be turned over, allowing one to cut both sides of a piece:
You may find the glossary helpful: http://www.shapeoko.com/wiki/index.php/Glossary
I used my Shapeoko XXL and cut the waste board to accept the t-track. works like a charm, drill through holes and use machine screws and nuts to hold it in place.
Drew this up — please verify before use
http://www.shapeoko.com/wiki/index.php/File:Unofficial_S3099_xl.svg
Please see official plans linked above.
Thanks you so much Will, strangely enough I got an email from Carbide with a drawing of the XXL wasteboard ; today !
It will be online tomorrow, On this site: http://carbide3d.com/docs/support/
I have now drawn up a sketch for a tapped hole wasteboard.
See attached screenshot.
Should I cut down the amount of tapped holes any further?
PS: this is probably a cheaper alternative for me ; I think I´ll do the tapped holes with inserts - instead of t-track.
a
If that meets your needs, go for it!
When I did a T-nut bed, I was constrained by local availability, which ratcheted up the price: http://www.shapeoko.com/forum/viewtopic.php?f=35&t=6045
Chris, do you have any pictures of this idea your put forward? Could be a valued asset for others (like myself, who have yet to purchase their Shapeoko). I’m just in the beginning learning phase.
Thanks in advance.
Michael
Just finished mine:
Details at http://www.shapeoko.com/wiki/index.php/User:Willadams#Wasteboard and http://www.shapeoko.com/forum/viewtopic.php?f=37&t=8332
Looks nice!
OK - so I´m trying to figure the “lesser” amount of tapholes needed in my wasteboard.
I have drawn up three alternatives - The clamps that are drawn up in the drawing be used for this setup.
I guess the alt.3 is the one to go for; last added screenshot from me in this thread with attached screenshot was too “messy” in the layout.
PS: I have used the outer diameter of the clamp as a measurement on how to “limit” the amount of tapholes.
Hello,
  • Will I need an exact router bit that = Ø 7.7mm; that equals the taps needed for my M6 inserts?
  • I have now bought inserts for my wasteboard. They will fit M6 bolts.
  • The taphole needed for these inserts for softwood ( I´m guessing that MDF will go under this category ) is 7.7mm
PS: I have a .125" bit that = Ø 3.175mm
Hello !
I guess this will be my last replay to the topic before making the new wasteboard.
I don´t have any extra limit sensors; so will need to cut the wasteboard in four pieces. I will use a lamello biscuit jointer system.
You can draw the holes in your CAD program as 7.7 mm and cut them as pockets
This was implied in my link.
Or, you know, a drill bit.
Only if your spindle is rated for a speed safe for the bit.
