I apologize but have searched for hours. Maybe I am missing something but in the database world, there is a transaction log when data is received. Is there a way when the carbide motion is doing a job to output, copy, log, mark the spot, or “what’s left file” of where the job was when any number of interruptions. Or modify/copy the file with a commented line that when you do the new job there is the option of beginning or marker/commented spot to start the job from. I do all my work from my garage and there are many times I need to pause it because I dont want to be running past 10pm and pause with the hope I dont loose the spot the next day to continue the job.
I find it frustrating to start a job after 15 hours of running. I have to go back to the software where I made the output file and create a vector around the stuff that’s leftover and export that for carevco to run.
I my novice head it seems like if it was writing grbl as it was sent that you could compare each file and see where if left off at.
Am I crazy that some programmer hasn’t thought of this or am I just ignorant and its already an option?
@gdon_2003@WillAdams , this is very helpful. Is there a way to capture the output or log of what line it’s on to a txt doc or what verbiage would I ask a programmer to capture the output from carbide motion.
