Rii Mini i8 controller problems
I could use some help with the Rii Mini i8 controller. I have used this particular controller for the last 6 months without a single issue…until now. When I attempt to move the cnc it will only move about 4 inches until it stops and then I have to the push the button again. I am not sure what happened but this sort of makes the controller useless. I really liked being able to use so I would appreciate any help.
Dead batteries maybe? Not sure what else one could do…if it’s a Bluetooth issue, then maybe updated drivers?
The controller works but I can only move it 6 inches per button push. Thanks anyway.
I would suspect a driver problem. You said it works but the functionality has changed. Windows is always updating things so maybe something in the setup on the host computer has changed the driver parameters. Maybe contact the OEM about the problem on how to program the keyboard compatibility.
Could also try un-installing the device from Windows along with the driver. Then re-install.
