Are Rockler’s T-track clamps compatible with the HDM hybrid table?
The clamps themselves?
Yes, if they match your stock/clamping setup — you’ll need to use the bundled nuts though, which will require replacing the star knob — unless you want to make new T-track nuts which have 1/4-20 thread.
Hi Will,
I should have included a link to the t-track clamp I was looking at. I like the style of this but wanted to make sure that the bottom portion that goes inside the T-track would be compatible with the HDM’s hybrid table.
Thank you.
The bottom portion of that would match Rockler’s tracks not ours, and it would use 1/4"-20 hardware, not the M6 which our hardware uses.
