Hi group,
I am trying to create something to display the wood ring i am building on my Lathe. I am able to create the rectangle to put the ring but I would like to have a round shape at the bottom. Only thing I can do is a square or rectangle bottom. HELP
You will need to make a rectangle which is longer from front–back, or a circle to get the shape you want, then use other geometry to restore around it:
