My Router won’t move down all of the way when measuring the tool. It barely moves down and then comes up “probing cycle failed”.
Does Carbide Motion show that your probe pin is active?
Check this thread.
How do you tell if your probe pin is active in carbide motion. Sorry if that’s a stupid question, I’m not overly technical
If you have a BitSetter, power up, connect to the machine, go to the Settings pane, then press the button on the BitSetter until it lights up — what shows under “Active Inputs” on the Settings pane?
