New to this site.
When using Advanced Carve in create and i use the enable area pocket tool, which tool routers first, the v bit or the flat bit?
(Design File: )
(stockMin:-317.50mm, -317.50mm, -12.70mm)
(stockMax:317.50mm, 317.50mm, 0.00mm)
(STOCK/BLOCK,635.00, 635.00, 12.70,317.50, 317.50, 12.70)
G90
G21
(Move to safe Z to avoid workholding)
G53G0Z-5.000
(Advanced.VCarve.Toolpath.1.-.Pocket)
M05
(TOOL/MILL,3.17, 0.00, 0.00, 0.00)
M6T102
The square endmill.
The endmill clears to input depth, then any areas too small for endmill the vee bit finishes pocketing and goes around and makes vee cut.
