Good Morning ,
Quick question, which rotour bits and toolpaths, would you suggest i try while creating this chain sign. Im still learning on what i should use for fine work.
Thanks team, and enjoy a great day!
Thanks
Bender
Good Morning ,
Thanks
Bender
What material are you cutting?
Is a V tool and a V carving toolpath not an option?
Have you done:
https://carbide3d.com/hub/courses/running-shapeoko/hello-vcarve/
and the preceding tutorials (Pocket, Contour, Hello World)?
Ill be cutting into pine, and i may need a refresher. As well appreciate the link, and how you have helped me along my journey over the past year.
Thanks for that Will
I will note that early on, I picked up a 90 degree V tool from a local home center and used (and abused) it for various cuts, so if you don’t have a #301 or #302, that may be an option.
