RPI Carbide Motion Issues
It looks like there’s a dependency issue with for the Raspberry Pi build of Carbide Motion. Installing the .deb file on the latest pi 4 32 bit raspi image using dpkg gives the following error.
Any chance dependencies can be updated in the .deb file? I’m imaging another sd card with the legacy 32 bit version to see if it works and will update once I’ve finished testing.
From what I can tell, they changed the package names in the latest repos, but I may be missing something? I don’t generall do work with linux packages.
dpkg: dependency problems prevent configuration of carbidemotion:
 carbidemotion depends on libqt5core5a; however:
  Package libqt5core5a is not installed.
 carbidemotion depends on libqt5gui5; however:
  Package libqt5gui5 is not installed.
 carbidemotion depends on libqt5widgets5; however:
  Package libqt5widgets5 is not installed.
 carbidemotion depends on libqt5network5; however:
  Package libqt5network5 is not installed.
 carbidemotion depends on libqt5gamepad5; however:
  Package libqt5gamepad5 is not installed.
 carbidemotion depends on libqt5serialport5; however:
  Package libqt5serialport5 is not installed.
 carbidemotion depends on libqt5websockets5; however:
  Package libqt5websockets5 is not installed.
Update: Running with legacy (Bookworm) works fine. Posting more to help people in the future than anyhthing else.
For support/the devs, would the package be able to be updated to support Trixie, or at the very least, the Carbide Motion for Raspberry Pi page be updated so that the OS dependency is “Raspbian 32-bit OS (Legacy|Bookworm)”?
