I have a g code saved in a .txt file format that I would like to run on Carbide Motion. When I try to load the file .txt does not appear as one of the supported file types. Anyone know how to get a .txt file into CM?
Change the .txt to a supported extension, .nc, .gco or maybe .gcode
If we were running this out of notepad, how would we change this?
If you can’t change the extension directly…
Save as → Choose “All Files” → Add .nc to the file name
You can add .nc to the filetypes handled by Notepad, or see: https://wiki.shapeoko.com/index.php/Programming#G-Code_editors
