Afternoon! Bit of a random one. I’ve been using the S5Pro since almost release. Typically cutting aluminium. Hundreds of hours of cutting with little to no issues.
I’ve come across a weird one. Some unusual stepping on the part but only on one side and only to a certain depth then it seems to correct itself. The width of the part once correct is spot on.
They’re just square plates really. 12mm thick. Was using an older tool for roughing.
Pretty well maintained but certainly close for some TLC. I’ll try giving the linear rails a once over but it’s a bit random as the steppers are pretty beefy and you’d hear it if they were pulling?
