I traced an image in CC without any problem. Then I made a number of changes to the traced image to clean it up. Is there a way to save the image to a format that I can use to convert to an STL file so I can import it back into CC and make a 3D design?
If you have vector outlines you can just use them to directly model in 3D in Carbide Create Pro:
https://carbide3d.com/hub/courses/create-pro/3d-tool-add-shape/
Thanks Will…I totally forgot about doing it that way… had STL on the mind ![]()
