Scale and Break Down complex DXF into buildable parts
Context: I purchased some cad files for a guitar which is set at a scale that doesn’t match the guitar and it has all of the components in the one file. I use carbide create and am fairly familiar with it but haven’t done this process before. I’ve looked for several hours across the internet and have seen tutorials that are either extremely rudimentary / doesn’t get into enough detail OR complicated to the degree that they assume a very deep level of knowledge about many different cad / cnc software. IE “Import it into inkscape and do it” as though the reader would know how to do that.
Question: Does anyone know of a tutorial that shows the importing, scaling, subdividing, setting tool paths and building a DXF / DWG file from beginning to end?
I’d bet that if you send the file via PM to @WillAdams (to avoid publically posting a commercial file) then he’d post a tutorial here for you to check out.
I work up importing a DXF to make a box at:
if you’ll send the DXF to me in a PM as Rob suggested, I’ll gladly work up a step-by-step for it here.
Okay, we import the file into Carbide Create and we get:
which has a couple of issues:
  • some geometry is open/unjoined when it would be better if it were closed (we will cover how to address these below)
  • no text/annotations (we will cover how to open the DXF in Inkscape to address this below)
  • there’s a tiny object off to the bottom left which interferes w/ how things zoom in (also addressed below)
As noted above, when the DXF is opened we get:
Drag-select to select everything which we wish to work w/:
Group Vectors:
Select All
shift-click on the group which we wish to keep:
delete and fit to screen now works:
A further step — select the selection of things which we wish to work w/ and note the size, deselect, bring up Job Setup:
and update the size:
save the file.
As noted, there is text on the DXF which Carbide Create does not bring in — it is a simple matter to open the DXF in a 3rd party tool and convert it into geometry so that it may be placed on a background layer for reference.
Open the DXF in Inkscape:
OK
we get a warning message:
OK
View | Zoom | Drawing
Drag-select to select what we wish to work w/
File | Document Properties
Resize Page to Drawing or Selection
View | Zoom | Page
Path | Object to Path
Object | Ungroup
Save as an SVG
In Carbide Create Import the SVG:
Bring up the Layers palette:
make a new layer:
Move Selection to Layer:
Hide the Default Layer temporarily:
OK
Again, select everything which we wish to work w/
Group Vectors
select all
shift-click on what we wish to keep:
delete
Fit
Use the Align pane to center things:
Bring the Layers palette up, lock the DXF layer and show the Default layer:
If things don’t line up perfectly, select everything on one layer, zoom in:
and drag to align things:
Zoom in on a section which we wish to work w/ and hide the DXF layer so that the state of the objects becomes obvious:
Ungroup
Select sections and Join Vectors to close them:
Repeat as necessary:
Note that in some instances it may be necessary to repeat the Join Vectors command:
The balance of things will be specific to the electronics which one has selected, but basically:
Cut out the pockets and drill holes for necessary features/parts
Do 3D modeling or work up suitable toolpaths for features such as the “Tummy Cut”
work up a suitable technique to flip the body to cut the features on the other side:
If you get stuck, let us know at support@carbide3d.com and we’ll do our best to work through any issues w/ you.
Will send the .c2d file via PM.
Once one has the file prepared, duplicate the file for each part which will be cut w/ a given operation and delete everything which isn’t necessary:
Set the stock size and thickness to match the stock you have:
Then assign appropriate toolpaths:
Where necessary offset geometry:
and to the outside for the outer profile:
c.f.,
