In the latest build, 474, the select box functionality has changed. Where in previous builds, any object touched by the select box was selected, not the entire object must be inside the box. Would it be possible to have one functionality when the box is drawn left to right and the other function when the box is drawn right to left?
This is an intentional update, there are two different behaviours:
https://carbide3d.com/carbidecreate/download/
473
- (NEW) Rubber band selection change - select down and only items contained in the rectangle will be selected (if grouped, any single item will select entire group). Select up and anything intersecting the rectangle will be selected.
Thank you. I had not stumbled onto the down vs up.
