Modify the numbers for bitSetterX and bitSetterY to wherever you put the setter. Save and close the file, reopen CM and reinitialize your machine and you’re done.
Is there a clause in there to adjust that initial plunge speed for the bitsetter? I have a couple of V bits that seem blunted to me and it feels like that initial plunge is aggressive.
I confirmed with IDC that my 30 degree bit from them looks damaged and they are sending me a replacement.
Probe speed is set by Carbide Motion, there is no way to over-ride it using GRBL settings.
Start a new thread with this as a post, using the “Feature Request” category. People can upvote it if they like the idea, maybe the devs will consider it.
