Finally got my used nomad 883 pro in the Mail; unfortunately the pin used for tool measuring was messed up. Got it all fixed, but don’t know how to make sure the height is correct?
Many tips would be great!
It’s a relative measure, so so long as the pin is secure and doesn’t shift randomly it should be fine.
Thank you! I appreciate your continuous help!
Quick question: the pin was bent from delivery; I was able to bend it mostly back, grind and sand it. Is this a piece I can order, in case I have any issues?
