Setting up a 3D file from Etsy
Given a purchased 3D file from Etsy:
this is set up to cut in Carbide Create by first setting up the Stock to match the design/the size at which it is to be cut:
Then, import the STL
adjusting the settings as desired:
verifying the 3D preview:
then right-click and trace the design:
OK
which may be offset by the diameter plus 10% of the tool which will be used for the 3D roughing toolpath:
Apply
Then a 3D roughing toolpath set up:
with a suitable tool selection.
Then, a 3D Finishing toolpath may be set up, repeating the process, first outlining from the original geometry:
Apply
