Setting z zero doesn't work
I just downloaded the current version of Motion. X&Yzero set okay, when it try to zero z the machine moves rapidly to the right and tries to bore into the table surface. When setting zero I have the following message “setting z zero will trigger a tool movement”
It apparently doesn’t know the correct position of your bitsetter.
You’re going to have to re setup your machine configuration.
Configuring a BitSetter location is now done as part of Setup:
@bobh, if you’re updating from CM <623, the behavior has changed (that makes me think of the Please listen carefully–our menu options have changed that every single automated phone system says…) There’s a comprehensive writeup at
https://carbide3d.com/blog/bitsetter-changes-carbide-motion/
I like the workflow. I can have the first tool, or a random tool, or a dowel pin, in the spindle when I touch down on the workpiece to set Z-zero. It doesn’t matter because the very first thing the machine does is to measure the currently-loaded “tool” to establish the machine Z coordinate.
