Settings for bit
I have a Freud Round Nose bit, will be cutting into Solid Ash, the bit is 3/8 radius, 3/4 wide. Im not sure where to start with the tool setting for the tool path in Carbide Create. It also has 2 cutter heads… My gut is telling me to set the following but im not sure… ANY HELP appreciated
Geometry
Diameter = 0.75 inch
Flute length = 0.375 inch
Include Angle = ???
Num Flutes = 2
No idea on 2D (I will be cutting plates, dont need 3d settings but if you know them would appreciate them as well)
Thanks anyone in advance
Chuck
I’d enter it as a ‘Ballnose’ bit, CC understands that geometry.
Number of flutes isn’t used anymore by CC, so the value doesn’t matter.
Once you pick Ballnose, included angle isn’t relevant.
I’m new also but have done a fair amount of woodworking. With handheld routers, lager bits sometimes required lower speeds in order to operate safely. Does he need to specify a spindle speed or just compensate by taking shallower passes?
thank you! very helpful, I didn’t know any of this. :slight_smile:
Thank you very much for replying, you do specify a spindle speed. ive been woodworking for a long time too and keep close eye on spindle speed. much appreciated that you are looking out to help :slight_smile:
I found a Freud 18-112 bit and went on the Freud site where they have a F&S calculator. They recommended from 350-550 IPM which is fantastically high for a hobby CNC. The calculator was set for 7/16" depth of cut (the only value available) and suggested 18000 RPM. So I agree with the RPM but a 60-80 IPM would seem a good idea. C3D does not have any 3/4" ball nose bits to compare the F&S to so make a custom tool and set your depth of cut around .05" per pass to start out with. If you get any burning drop the DOC to a shallower pass. The 18000 RPM seems reasonable. A 3/4" bit is a lot of mass turning on a trim router so just depending on your material you may need to do a test run on some scrap to dial in your F&S.
The C3D #202 1/4" ball nose does a .040" depth of cut at 60 IPM. Their F&S are conservative so try that to start with. Your bit is 3 times bigger but could be a starting point to adjust up or down depending on material hardness or things like cherry which burn really easy. Just do a test in scrap and not on your actual project to get the adjustments down.
