Hello,
Here is the setting screen for Dmap2Gcode.
It is asking for “Gcode Heading” and “Gcode Postscript”. My question is, will these settings work or do I need something more SPXXL specific?
Hello,
In the Header:
Get rid of G64.
I’d set the units (G20 for inch or G21 for mm)
If you want it to behave similar to a Create file, add a G53Z-5 (mm) or G53Z-0.2 (inch)
Leave the M3Sssss command last
The Postscript should be ok
I figured there would be more for some reason.
