I want to use the marker that came with my CNC to draw out a design I did so I can see how it will cut and make measurements.
What settings/tools should I use to do this? Any idea?
Thanks!!
Thanks!!
Please see:
You can get or make a fancy spring or gravity loaded pen/pencil holder.
I just wrapped some tape around a sharpie & used the 1/2" collet.
Speed: 0 Feed: 200 IPM (Or as fast as it will go) Depth: 0 or 0.001"
I just moved the spindle down until it started to leave a mark & set zero
Thank you both very much! Very helpful.
