Does anyone have the hole pattern for the base under the hybrid table? I’m wanting to create a special fixture and want to remove the aluminum slats and replace them with an aluminum plate. Thank you
Hey Keith, I stumbled across this post. The entire base seems to be modeled in Fusion, so you should be able to get the info you need:
I went ahead and measured out everything and did it in Fusion. If anyone needs a copy just let me know. I did cut it and it worked out accurately.
