Shapeoko 3 set up
So im finally getting ready to set up my machine i bought used. It has the HDZ Z-axis and bit zero has a watercooled 110 spindle.
Where do i start
I used the manual when I bought my used 4XL. Even though it was “assembled” I found it was good to use the manual to make sure everything was assembled the way it should be. Good thing I did … I found a lot of loose, incorrect and some missing hardware.
The SO3 and HDZ manuals are in this link
https://carbide3d.com/hub/manuals/
We are updating our documentation to:
For the Setup Wizard see:
What liquid is best for water cooled spindles Antifreeze, distilled water or something else
I used a straight mixture of RV anitfreeze in the one I got from PwnCNC but I understand C3D recommends a 50/50 mix of antifreeze and distilled water. I don’t know what the advantage of a mix would be other than cost and perhaps lower viscosity.
This wheel is touching nothing how do i adjust it
You should find an adjustment for the eccentrics in the manuals and/or assembly guides that were linked to above
20260418_183519(2)
Is that normal
With the power on? No. If the belt is secure and the pulley set screw in place, most likely you have a failed stepper driver for the right Y-axis.
Power off just checking before powering it on
Movement with the power off causes the stepper motors to work as generators, pushing current back up to the stepper drivers — if not done slowly/gently/deliberately, it is possible to push up so much current that one damages a stepper driver chip.
The way to check a machine is with the power on, jog it to the center of motion for each axis, install a probing pin, then grab the tip of that pin and try to shift the machine in all possible directions — it should be steady/unmoving, if not, investigate what allows the motion. For an SO3 the usual culprits are:
  • belt tension
  • belt condition
  • loose pulley set screw
  • loose eccentric nut/V-wheel
  • wiring fault
  • blown stepper driver
Nice i hope i didn’t burn my chip out
