Shapeoko 3 XXL Enclosure Build
Progress report on my dust management system.
Here is the CNC end. Got my Suckit Dust Boost the other day (thanks Jenn!). One thing I struggled with is how to handle the hose. My original plan was a 2.5" flex hose like you see on the dust collector below. But ended up using the Shop Vac 1-1/2" hose it came with. Its the perfect balance of rigid and flexible.
In order to keep the hose under control for the entire range of travel I drew up a hose clip in Fusion 360 and 3D printed it. Works perfectly.
Here is the vacuum side of the table. Unfortunately I do not have the available height for a Dust Deputy, so trying one of those cheap bucket cap solutions. Preliminary testing just vacuuming up a pile of trash are good. I hope it works ok.
