In the middle of a job! Please help.
Been Running my Shapeoko 4 xxl for a couple of months, with no problems. Turned it on this morning and got this error when initializing. RX light for USB connection on motherboard flashes green and device homes properly, then TX light flashes amber and error code comes up:
“g-code words consist of a letter and a value. letter was not found”
I found the green ground wire had disconnected, but no difference when I reconnected it.
I cannot find any helpful articles in the forum.
Here are my machine settings:
Machine: Shapeoko
GRBL Version: 1.1f
Carbide Motion 635
Machine Controller State: INIT
Grbl Cycle: Idle
“bitRunnerEnabled”: true,
“bitSetterEnabled”: false,
“bitSetterX”: 0.0,
“bitSetterY”: 0.0,
“bitZeroType”: 2,
“connection”: 1,
“lastConfigSent”: 3,
“lastProbeIndex”: 0,
“lastSizeOption”: 0,
“odometer”: [
“cleared”: false,
“minutes”: 229.33435000000037,
“startDate”: “2024-02-18”,
“travelX”: 400954.49378299713,
“travelY”: 326627.40751457214,
“travelZ”: 37305.10981106758
“showCarbideRouterRpm”: true,
“spindleType”: 0,
“travelX”: -865.0,
“travelY”: -871.0,
“travelZ”: -95.0,
“version”: 0,
“webhooks”: ,
“workOffsetX”: 823.3499755859375,
“workOffsetY”: 718.5,
“workOffsetZ”: 78.06500244140625
0 = 10, Step pulse, microseconds
1 = 255, Step idle delay, milliseconds
2 = 0, Step port invert, mask
3 = 5, Direction port invert, mask
4 = 0, Step enable invert, boolean
5 = 0, Limit pins invert, boolean
6 = 0, Probe pin invert, boolean
10 = 255, Status report, mask
11 = 0.02, Junction deviation, millimeters
12 = 0.01, Arc tolerance, millimeters
13 = 0, Report inches, boolean
20 = 0, Soft limits, boolean
21 = 0, Hard limits, boolean
22 = 1, Homing cycle, boolean
23 = 0, Homing dir invert, mask
24 = 100, Homing feed, mm/min
25 = 2000, Homing seek, mm/min
26 = 25, Homing debounce, milliseconds
27 = 3, Homing pull-off, millimeters
30 = 24000, Max spindle speed, RPM
31 = 0, Min spindle speed, RPM
32 = 0, Laser mode, boolean
100 = 40, X steps/mm
101 = 40, Y steps/mm
102 = 200, Z steps/mm
110 = 10000, X Max rate, mm/min
111 = 10000, Y Max rate, mm/min
112 = 1000, Z Max rate, mm/min
120 = 500, X Acceleration, mm/sec^2
121 = 500, Y Acceleration, mm/sec^2
122 = 270, Z Acceleration, mm/sec^2
130 = 845, X Max travel, millimeters
131 = 850, Y Max travel, millimeters
132 = 95, Z Max travel, millimeters
Maintenance:
Travel (km) 0.40, 0.33, 0.04, 3.82 Hours since 2024-02-18
Queue Empty
| Edition | Windows 10 Home |
| Version | 22H2 |
| Installed on | 3/14/2021 |
| OS build | 19045.4291 |
|Experience|Windows Feature Experience Pack 1000.19056.1000.0|
| Device name | LAPTOP-VD1N1U24 |
| Processor | AMD A9-9425 RADEON R5, 5 COMPUTE CORES 2C+3G 3.10 GHz |
| Installed RAM | 8.00 GB (7.47 GB usable) |
|System type|64-bit operating system, x64-based processor|
