Finally finished the installation of the new machine. Practicing movements heard a little “clink” and found this part, and couldn’t find where it goes. Any 4 owners that can take a look and let me know.
Thanks
Thanks
I do not own a 4, only a 3, so I’m probably wrong.
My guess would be z-axis carriage end-stops on the x-axis gantry, should be two on either end.
Thank you. Found it it was the limit switch at the end of the Y Axis. The little thing is the one that tells the switch I am here. The hole is a little bit wider so when I tried last night didn’t fit. I am posting a picture just in case somebody has the same problem.
