Shapeoko 5 Pro Extension Cables to Controller
I have just completed the assembly of the Shapeoko 5.1 PRO and would like to relocate the controller to the other side. Cannot mount it to the table and don’t like it sitting in the space behind X gantry.
Is there are any extension cables I can order for this purpose somewhere?
I don’t know the answer for the 5 pro but I’ll say I ended up splicing my extensions in myself when I moved my Nomads controller to the outside of an enclosure.
If you find that you can’t get an extended harness from sales, it’s not terrible to extend them yourself in an evening or so.
Exactly what I had to do
@krudoy
And all is well? No issues with your extension? What length did you extend it?
good for now :slight_smile:
10 ft 18awg. Appeared exactly as long as I needed.
Wrapped each into the cord protector: Amazon.com: Alex Tech 25ft - 1/2 inch Cord Protector Wire Loom Tubing Cable Sleeve Split Sleeving For USB Cable Power Cord Audio Video Cable – Protect Cat From Chewing Cords - Black : Electronics
Thanks for the reply and info for the rest of the forum.
