Shapeoko 5 Pro (NEW) and custom table For sale Kansas City area
Brand new Shapeoko 5 Pro 4X4 with VFD spindle, endmill starter kit, clamp kit, and bitzero V2. Used one time flawlessly, spoil boards are unscathed. Sits on a fully welded metal frame on a custom made one piece butcher block top. Purchased Oct 3, 2023, delivered Oct. 16, 2023.
5 Pro - Asking what I paid for it (4795.00 OBO) but it comes fully assembled and ready to use. I also have some additional bits to go with it and is also setup for air for a laser and dust blow off.
Table - asking 2500, I am willing to negotiate this, once you see it in person you will fully appreciate the quality of the build.
I will sell the 5 Pro separate if needed as the table would be awesome by itself in any shop. I currently have too many irons in the fire and thought I would use this but to date I’ve only used it once when I finished the table to do a test cut with a premade file. Located an hour south of downtown Kansas City. I can get it loaded onto a trailer for you.
Table
Table Drawers
Table lift
A little more about the table: All metal construction 60x60 metal frame, heavy equipment casters with spin down feet. 64x64 2x4 butcherblock top. I made a 8’x8’ router sled to surface this top.
Handmade front opening drawers on ball bearing soft close drawer guides. The whole top tilts up from the rear to expose a large storage box inside the table. The top and the machine are lifted by a pair of 200lb struts. Its about 40lbs for the first six inches and then it goes up on its own. I was planning on installing a rubber gasket to keep the dust to a minimum inside. I made the brackets to hold the electronics and wired and mounted them to still allow pass-through and lift with the table. Usb was extended to a 4 port hub on the front of the machine as well as the e-stop which is easily relocated to your preference. This table is a beast.
