Gee! Sorry I asked!
As would Stepcraft-US’ guidance that their customers use GWizard for feeds and speeds!.
Stepcraft claims that their D.210 machine will have less than 0.005" deflection at 4.5 lbf. (When I asked about the new Q-Series machines I was told “I apologize but I do not have that info - the accuracy of the machine is down to 0.001”). GWizard, which considers 0.001" endmill deflection the upper limit for “Aggressive” milling, would likely exceed the machine’s 0.005" deflection force by over 6 times. It would likely also exceed the power available from the “spindle” by significantly more than 24%. So, “pick your poison”.
Hi @gmack,
can you elaborate on how you derived those chiploads ? I’m surprised the 1/8’’ values are twice as large as the 1/4’’ ones.
thanks @gmack
These S&Fs in the table - are they for the toolpaths generated by Carbide Create or for other CAM software toolpaths that have ramping capabilities (F360, Vectric etc)?
Having a DOC/WOC set the same (e.g. 1/4") seems a lot if not ramping from what I understand. You would use these settings for profile cuts - such as for a full-depth cutout? Seems aggressive to me or am way too cautious? I am still a novice at this.
Is this correct? or am I missing something?
I adjusted the chiploads to provide what seemed like a reasonable machine force of ~ 3.33 lbf. Then I checked the endmill manufacturer’s recommended maximum chiploads for the material being cut. Yoniko provides feed rates and speeds for their endmills from which the workbook can calculate chiploads. FYI, I corrected an error I found in the endmill deflection calculations when shank diameters exceed cutter diameters. The tables above are now corrected for 0.001" of maximum endmill deflection. Note that the Yonico endmills aren’t rated for Aluminum though. Here’s the spreadsheets showing details.
0.25 and 0.125 Inch Endmills.zip (114.4 KB)
I’ve been using VCarve, so don’t know much about Carbide Create. But I believe you should be able to have it safely plunge slowly enough to that depth without ramping. I also don’t know how to have it cut a slot (WOC = endmill diameter). DOC = WOC = endmill diameter seems to be a “standard” for endmill manufacturers’ feeds and feeds charts. I assumed that WOC = endmill diameter was the case with CC’s too (some of which show DOC more than WOC). 3.3 lbf seems plenty safe to me, but you can always start at some feed rate and decrease/increase it as much as +/- 100% in Carbide Motion while running. Maybe others with more experience will chime in!
Very interesting approach, my interest is piqued (again). If I am not mistaken, dropping all constants from the equations,
- Torque is power over RPM.
- Power is MRR over K_factor
- MRR is WOCxDOCxfeedrate
- Chipload is Feedrate/(NbFlutes x RPM)
- cutting force is torque over endmill radius
so cutting force is proportional to (torque)/(endmill radius)
so to (power)/(RPM x endmill radius)
so to (MRR)/(K_factor x RPM x endmill radius)
so to (WOC x DOC x feedrate)/(K_factor x RPM x endmill radius)
so to (WOC x DOC x NbFlutes x Chipload) / (K_factor x endmill radius)
What this table is telling me is that since you are choosing a target cutting force (3.33lbf), for a given endmill and WOC/DOC the key is to produce a constant Chipload / K_factor ratio ? Which gives these “surprising” chipload variations, that in fact onlty reflect the natural variations in K-factors of the listed materials.
A few follow-up questions:
- When looking at the values, the CL/K ratio is indeed almost constant, EXCEPT for the 6061 Al for 1/4’’ and 1/8’’, and Acrylic for 1/8’’. Did you tweak those differently ?
| CL | K | CL/K | CL | K | CL/K | ||
| MDF | 0.0037 | 35 | 0.000105714 | 0.0018 | 35 | 5.14286E-05 | |
| Torrey Pine | 0.0025 | 24.11 | 0.000103691 | 0.0012 | 24.11 | 4.97719E-05 | |
| Yellow Poplar | 0.0024 | 22.68 | 0.00010582 | 0.0012 | 22.68 | 5.29101E-05 | |
| Santos Mahogany | 0.0018 | 17.5 | 0.000102857 | 0.0009 | 17.5 | 5.14286E-05 | |
| Baltic Birch | 0.0010 | 9.45 | 0.00010582 | 0.0005 | 9.45 | 5.29101E-05 | |
| Acrylic | 0.0020 | 20.06 | 9.97009E-05 | 0.0020 | 20.06 | 9.97009E-05 | |
| 6061-T6 Aluminum | 0.0005 | 3.34 | 0.000149701 | 0.0010 | 3.34 | 0.000299401 |
I missed the key part of the story: why would it be the best strategy to aim for a constant cutting force?
why 3.33lbf ? It’s such a specific value that I guess you derived it from something else ?
What happened to the 18lbf machine limit we discussed earlier ? The spreadsheet now has 3.33lbf as the machine limit
EDIT: and I realize now that this discussion should rather continue in the “origins of chipload” thread ?
The ability of the CNC machine to counteract cutting force limits performance if the cutter and spindle don’t. Counteracting those cutting forces causes deflection which causes the cutter to deviate from the intended location as well as other nasties. Even though Shapeokos can supply up to 18 lbf, the resulting machine deflection would likely be unacceptable. That’s probably why @Vince.Fab (and @Luke) are replacing at least some of the V-Wheels with linear slides.
3.3 lbf force was kind of arbitrary but seemed like a relatively safe value based on Stepcraft’s D.210 specs.
I think I’ll add the option of having feed rate determined by allowable force (perhaps determined by deflection measurements) rather than chipload. That seems to make more sense to me since actual chipload values aren’t very important if they are kept below the cutter manufacturers’ recommended maximums.
I’m confused, are you saying that 3.3lbf is enough to deflect the Shapeoko? Have you done any measurements? I find it hard to believe, it seems very low, more like the deflection of the XCarve. I saw a video of someone standing on the frame and the deflection was not noticeable (albeit not measured with a caliper).
The cutting forces appear at the bottom of the endmill, so that’s where deflection needs to be measured. I measured about 14 lbf for 1/16" deflection along the X-axis and about 10 lbf for 1/16" deflection along the Y-axis.Well, as long as they are above the golden value of 0.001’’ I guess.
Also, how did the thermal aspects disappear from the equation? Just because of high RPMs hence smaller forces hence small amount of heat?
I hate to bring this back to the table but 27000 RPM will not be acceptable for everyone.
Ok, we know the Z axis is the weak link but how do we get from 10 to 14lbf to 3.3lbf? It would be interesting to see what measurements a Shapeoko with HDZ gets.
All of the V-wheels are weak links, it’s just a matter of degree. I figured that 1/52" deflection would be a lot more acceptable than 1/16", so it was kind of arbitrary I guess.
Ok so I went to my workshop and replicated your experiment. I placed the spindle on the center point rapid position with a 1/4in 201 endmill. I used our luggage scale and measured 20lbf along the X axis and 15lbf along the Y axis. I have an EasyTram Z plate and upgraded V wheels from Mr Beaver.
It appears that even BW, who probably originated the (now discredited?) “chip cooling” myth, isn’t even a believer anymore. The following shows GWizard recommending a 0.0002 chipload.
IMO the thermal aspects never entered into the equation, but I wonder how much wood burning would result from the slow feed rate shown above!
The table was just a simplistic “straw man”, it’s easy enough to generate more of them. I’ll add the force driven feed rate option when I get around to it.
Approximately an extra 5 lbf on both axes for a 1/16" deflection then? Note that the amount of spindle and bit stickout (their vertical position with respect to the load carriers) will affect the measurements too.
My Makita Spindle is all the way in the mount, bit stick out is 1 3/16in. Measured about 1/16in above my wasteboard which is 3/4in above the OEM wasteboard.
To be fair, it only outputs this 0.0002" chipload when the turtle/hare slider is at the minimum (1%), and goes up to 0.001" as soon as one selects at least 15% on the slider. This slider is probably the top reason why I don’t really use GW anymore, since I have yet to figure out what part of this slider range is actually appropriate on a Shapeoko. As you noted, the 1% position might as well be called the “bit burnishing setting”.
If I know anything about me, I will want to experiment to measure actual endmill temperature depending on the chipload & K factor, to be convinced. I wanted to contribute to your K-factor database anyway by doing test cuts in as many different materials as I have on hand, so it will kill two birds with one stone.
Anyway, it seems to me that no matter what approach we take, we end up concluding time and again that anything in the [0.001" to max chipload for the endmill size/manufacturer] range will work, and that more specifically [0.001’‘-0.002’'] is better at high RPMs (while I still believe that at lower RPMs thicker chips are needed, but I have yet to prove it or convince myself otherwise)
You must have been close to having the X-axis stepper slip. Did you check that? What size Shapeko do you have? (My measurements were on the small one with a Makita fully lowered in the current stock mount and about 1/2" thick spoil-board.) So, in light of your measurements, what force would you put into the calculator to come up with an initial feed rate with that stick-out? (This link has some issues, but shows the basic idea.) Is your EasyTram Z plate pink? Do you have upgraded V wheels on all 3 axes? Does/will Carbide 3d sell them? ![]()
