I have several projects I run quite often and I’d like to create macros in Carbide Motion to set up the zero XY points (I know I’ll have to do the Z manually) that I use for each job. An example would be a front left, while edge machining (off the front of the machine) I’ll use a position somewhere near the middle.
While I can move the carriage around using GCode, I’m having trouble finding the GCode to tell Shapeoko to set XY to zero.
G28.2 - home the machine so we know we have a good reference
Set zero XY (but not Z)
G0 Xxxx Yyyy - my known pre-set XY start for the job type
What GCode do I need to tell the machine to set the XY zero?
Thanks, it’s not Grbl supported, but maybe Motion handles it. Carbide Motion has its own gcode “checker” where it preprocesses commands sent to the controller. Motion may intercept that and send a $H to the controller.
Have you tried it? I wonder why they’d pick that command to add.
Yes, both $H and G28.2 work. TBH I’d forgotten about $H, but since the controller specifically supports it then G28.2 then no reason not to use it.
I have another (smaller) CNC that uses G28.x commands for other things too, so it didn’t seem out of place.
Given you can send GCode to the Shapeoko without Carbide Motion it’s likely to be the machine that knows how to use it rather than CM intercepting and changing.
I’m using CM because it just works with Shapeoko, but I use UGS for the other machine.
Thanks. I’ve also tried UGS on the Shapeoko, but since I run both from the same PC, I used USG for one and CM for the other so it’s obvious to me which software is for which CNC
When I get the S5 I’ll need another PC since it will be located further away.
