Does the maintenance kit include the new Steel Belts and the eccentric nuts from beaver
Yes.
- Eccentric HD Nuts (8pcs)
I’ll let folks know we should update the belt listing to differentiate fiberglass (for Z) and steel core (for X and Y).
You can buy the https://shop.carbide3d.com/collections/shapeoko-hd/products/shapeoko-hd-eccentric-nuts?variant=29455694200893
Currently they are out of stock but will come back. I upgraded to the HDZ and I really liked the larger eccentric nuts.
Hi Will, are the belts for z and xy different?
Yes.
Z is a fiberglass-reinforced endless 520mm belt 6mm wide
X and Y are steel core belts of suitable lengths 9mm wide
Either are Gates GT2 profile, 2mm pitch
See: https://wiki.shapeoko.com/index.php/Belts_and_Pulleys for more information
Great, thanks for the info.
