When I turn on my shapeoko 3, the light comes on and goes out immediately ik mijn shapeoko 3 aanzet brand het lampje en gaat meteen uit
Which light? On the controller? Or the power supply.
First, unplug everything.
Then, plug in only the power supply (while it is not plugged into anything) — it should promptly light and stay lit — if it doesn’t, probably needs to be replaced.
If the power supply checks out okay, unplug it from the wall, then plug it into the machine, then plug back into the wall, then if need be, toggle the in-line switch to “on” — what happens?
If the problem isn’t the power supply, it’s probably the controller, we have replacement parts at:
