I have somehow lost the small metal disk that fits perfectly into the top of my bit setter. How do I get another? I currently have a 1/16" thick acrylic circle I cut out on my laser in its place but it’s a little too thick.
The measurement is relative, so too thick shouldn’t be an issue.
The acrylic getting chewed up is.
The magnets were 11mm diameter. ~2mm thick or you could just fill with a metal impregnated epoxy.
Or, get a replacement button:
Thanks. So the bit setter should work just like before (until the acrylic gets torn up)? No measurements will be off on the Z axis?
It will change as the acrylic gets torn up.
