When I home machine the Y axis will overshoot the switch and hit solid stop and alarm out. The switch lights up. Sometimes it will home but in the wrong position and the carriage barely hits solid stop. The tool offset position is also off in Y. I adjusted the switch up closer and same problem. I have to home a few times and then it will home properly. Suggestions?
