Shapeoko Pro XL Assembly belt question
I have started putting together my Pro XL and the belts seem to be way to long. is it ok to trim the belts? I assumed the belts were one length to include the XXL size, but I wanted to ask before I just go cutting them.
I had the same question when assembling my pro xl and you’re correct, you just need to cut them down :slight_smile:
Awesome. Thank you for the response. That’s what I thought but at this price I wasn’t cutting anything until I asked. :rofl:
I left about 4 inches on both ends. Don’t know why, but I did. The other day I dropped a sharp piece of metal that hit the belt. Of course. I repositioned my belt to get rid of my fudge up.
Good Luck. Enjoy the machine
As @Zman suggested make your belts a little longer. After you get up and running you can trim them down to size. The issue is once they are cut you cannot make them longer. If they are too long you can cut them down.
