Shapeoko Pro XXL Fusion not using BitSetter after tool change
I am trying to learn how to use Fusion360 to create projects to cut on my Shapeoko Pro XXL. I manually created the 278Z tool and 112Z tool (yes cutting aluminum). I watched a video on YouTube on this.
As far as I can tell everything is set up correctly. I initialize my machine, it sets Z,X,Y. Then asks for a tool and sets the tool with the BitSetter. I then zero on the work piece.
I load a new file and hit start. This is where things are a little different. Instead of a popup box I am getting “Manual tool change T1” so I install the first tool and hit start again. Then the Shapeoko spins up the spindle and moves to cut. It is not measuring the new tool.
I have downloaded the most resent post processor. I thought maybe it was the “Manual Tool Change” option but I tried with it checked and unchecked.
What am I doin wrong?
**** EDIT: Originally I had imported the machine from the creator of the video I was following and changed the post processor of that machine to the newest PP.
This time I completely deleted the machine and created a new one from scratch, using the updated PP. It seems to be working now.
We have a page on configuring Fusion 360 at:
https://my.carbide3d.com/faq/fusion360/
Does that help?
I had seen that earlier. My settings where the same, relatively because Fusion has a different looking page now then when this screen shot was taken.
I did get it fixed though. Originally I had imported the machine from the creator of the video and changed the post processor of that machine to the newest PP.
Thank you
This topic was automatically closed after 10 days. New replies are no longer allowed.
