Hello,
Recently assembled Shapeoko Pro XXL.
On the first day, we were able to connect a computer and ran a job successfully.
On day 2, the controller board started malfunctioning. The root cause is unclear. When we turn on the switch from the power supply to the controller, the board tries to turn on (regardless of whether or not the Shapeoko Pro’s front right plate power button is toggled on/off).
The LED lights on the controller board blink blue, and the board sends a pulse to the X, Y, and Z motors. The pulse is audible. See and view here: Shapeoko Pro XXL Motor Controller / Power Supply Issue - YouTube
We tried unplugging all of the components (limit switches, power, bitsetter, etc) and plug in each motor one at a time. In every case, the PCB just cycles. Sending a pulse to the motor once every 3 seconds or so.
When nothing except the power input is plugged into the board, the LEDs blink at the same frequency (but without the audible pulse from the motors).
If the power button to the front panel is plugged in, the power button blinks blue in sync with the LEDs on the board.
When the board draws power, the green light on the power supply turns off (or is so faint it can’t be seen).
Shapeoko Support sent a new power supply. We’re still experiencing the same symptoms.
The limit switches no longer respond when they are plugged into the board and when we hold a wrench over them.
Suspecting the issue is either the board or the power supply. Was wondering if anybody else experienced this? Or if anybody has any ideas of what else the problem could be? Help/advice much appreciated. Thank you in advance.
