Attached a link to my set up issue… Any help is appreciated…
I don’t have a Pro but I have a 3XXL with a bit setter. I didn’t see in your video where you set the bit setter location.
You need to setup your Bit Setter.
https://docs.carbide3d.com/assembly/bitsetter/bitsetter.pdf
How do you set the bit setter before homing the machine? Instructions state to Home first and I can’t get to the Jog screen until I successfully initialize?
Power up, connect to the machine, go to Settings, clear the checkbox for BitSetter — that will allow the machine to initialize.
Thanks, that worked! Now off to my next issue ![]()
