Does anyone know where to purchase the t-track that is used on the Shapeoko machines. I have T-tracks but the essential work holding kit does not fit.
The Hybrid T-track is specific to the Shapeoko 4, Pro, HDM, and 5 Pro machines — it is not available for other machines.
You can still use the Carbide 3D workholding options — except for the Teez-Nutz which are specific to the Hybrid T-track.
Usually a square steel M6 nut will fit and work — it just doesn’t offer much thread length, so you have to size the bolt, or use a long one paired w/ a wing nut, or use a nylon bolt inserted upside down which can be cut to length if need be.
