I have been recently cleaning and recalibrating my xxl and am finding that the x axis travels further to the right side than the left, leaving the total working width to 32 3/4" versus 33" in my last project I needed every bit of 33" so this is a concern for me.
I manually jogged the machine to both ends and this is what I’m getting. Is there a simple fix for this?
There is nothing blocking the left side to prevent it to travel any further.
Yes. You just need to set the origin and movement appropriately to allow for that — may take a bit of experimentation, and I’d suggest starting by calibrating:
I calibrated using the tone method works great, thanks.
So far everything else is coming out square down to a 64th of an inch (I spent all day doing this)
So safe to say I can leave the extra gap of the left side alone as is per normal operation of the machine? It’s the only noticeable difference I can spot on the machine at this point
