Hello,
My Shapeoko has power but doesn´t turn on. If i move the machine by hand all the lights go on, but when i try to start it with the power button it doesnt work!
Some one had this problem before?
Thanks
Hello,
Thanks
Is the power supply plugged into an outlet with power?
Is the in-line switch on the power supply on as well as the switch at the front corner? Have you tried all four possible switch positions?
Hi will,
yes everething has power. when i turn on the switch the machines turns on and shuts off… i move the machine for a new place, do i need to setup the machine again?
Setting up the machine if you can connect to it won’t hurt, and if the problem is corrupt settings should fix things.
If that doesn’t address things, let us know at support@carbide3d.com
It doesnt work, i need to turn the machine on for that.
Sorry for bad terms here in advance, but had this same thing happen and the inline switch was bad on the power cord. I found this by jiggling the lines at the switch back and forth and could get it to turn on and off. To fix this i split the wires and removed the inline switch all together.
